BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
Use this procedure to display information about BFD IPv6 neighbors.
  1. To enter User EXEC mode, log on to the switch.
  2. Display BFD neighbor information:
    show ipv6 bfd neighbors
  3. Optional: Display BFD neighbor next-hop information:
    show ipv6 bfd neighbors next-hop WORD<0-128>
  4. Optional: Display BFD neighbor information for a particular VRF:
    show ipv6 bfd neighbors vrf WORD<1-16>
  5. Optional: Display BFD neighbor information for a range of VRFs:
    show ipv6 bfd neighbors vrfids WORD<0-512>
The following example displays BFD session information for an IPv6 neighbor.
Switch:1>show ipv6 bfd neighbors
                                          BFD Session - GlobalRouter
MY_DISC    YOUR_DISC  NEXT_HOP                            STATE      MULTI MIN_TX MIN_RX ACT_TX DETECT_TIME REMOTE_STATE APP    RUN
1 	     0 	     2001:DB8:0:0:25AB:0:0:1             Down       3     200    200    1000   0           Down         O
  1 out of 1 BFD session displayed
APP and RUN Legend:
        B=BGP_IPv6, O=OSPFv3, S=IPv6 Static Route
The following table defines parameters for the show ipv6 bfd neighbors command.
Variable
Value
WORD<0-128>
Specifies the next-hop IPv6 address in the format a:b:c:d:e:f:g:h.
vrf WORD<1-16>
Specifies a VRF instance by name (the string length ranges from 1–16 characters).
vrfids WORD<0-512>
Specifies a range of VRFs by ID number (the ID ranges from 0–512).
